Just a quick tip...
Replacement rear wiper blades for the MultiWagon can be a bit pricey - they have a custom plastic frame - but you can do it cheaply - just get a pair of cheap wipers from a pound shop (Poundland, Pound World etc)- the cheap ones usually have a plastic strip with the rubber blade embedded in it, rather than the more expensive blades, which are usually solid rubber with metal strips stiffening them. So if you get a cheap pair, just slide out the existing rubber from the plastic frame, and cut the new blade with a hacksaw and slide it in - it will be a snug it but will go it with some gentle force. The frame has a lip at either end to stop the blade slipping out.,
