Technical  Replacing Rear Light Bulb
Lordii
One of my rear brake lights are out, drivers side.
How do i remove the tail light?
I've tried removing the light unit by removing the two nuts from outside the vehicle with the door open.
It's still seems attached, I have removed the small cover inside the van and there are no visable screws.
There are two black plastic caps, I read somewhere that they could be screw head caps but I can't pry them off (Don't wanna force them to much).
I had to do this recently. It's dead easy. Undo by hand the two triangular-headed screws on the inside of the van, the whole light unit comes off, and you can simply swap the bulbs. Brilliant!
OTOH perhaps you're not talking about the same model.
It's a good idea to say which one you're talking about. Mine is a 2004 2.0 JDT SX.
It's all good I figured it out. The inner side had the two nuts, the outside it held in with like two plastic balls that pop into a joint. Just had to pull a little harder. Cheers!
