Hi, another newbie here -- I searched through the forum but couldn't find any related info....
I have a 1994 (L) Uno Start (IE Fire, 5 Door, 999cc) -- my mum's car originally, I just recently obtained it from her as my first car
Unfortunately, while closing the sunroof yesterday, I broke the closing mechanism. It's not likely to be fixable as it was part of the self-contained plastic unit which broke, and a high-tension part too. So I'm looking to try and get a new/used one from elsewhere.
The problem is that I've never seen another similar sunroof mechanism around. Rather than the "tilt/rotate" handle, mounted in front of the sunroof, which seems to be on most cars (and even in the Haynes Uno manual), this is a simple screwing mechanism attached to the rear of the sunroof pane, pivoting on a bar attached to the inside of the roof, and controlled by a large (10cm dia) "jam jar lid"-style rotating handle mounted on the underside.
The mechanism can be easily removed as the roof pivot just clips on/off, and the unit itself is just screwed/bolted to the sunroof glass. I just ned to find one of these fabled units!
Anyone have one sitting around spare, or know of anywhere that would do them? Otherwise that tent peg is going to have to stay wedged in the mechanism to keep the sunroof levered shut
