General Replacement Gear Knob
redhotferrari
Hi Guys,
New to the forum, so hope you can help! he gear knob on the wifes car is really loose and keeps coming off, not good when driving!!
Where can I get a replacement one? Do Halfords do anything?
When I pull the old one off, the stick has spindle type bit left sticking up and in inspection of the inside of the knob, the collar that I assume grips the spindle is broken.
Any help would really be appreciated.
Many thanks
Welcome to the forum (y)
I have replaced my gear knob with a richbrook one like the one below off ebay that comes with an alan key to 'clamp' it on the gear stick.
http://cgi.ebay.co.uk/Richbrook-Bla...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
Hope this helps,
Sam
(p.s. when you buy one make sure it is lift reverse compatible and that the reverse is on the bottom right of the gear knob - which the one above is)
Hello mate and WELCOME TO THE FORUM!!
....assuming you have a lift reverse gearbox and not a standard one obviously.
Is very common for them to come off. If you would rather keep your original one than go after market, then you can use some Epoxy glue and it will never come off again. Just spread it on the inside of the gear knob and then give it a whack on. Let it try and your done.
Places like halfords have a wide selection of gear knobs, as do places like e-bay.
Hope that helps,
Alan
If this is a Mk1 Punto (push down to select reverse), I found that hot glue sorted it all out. The glue gun has to be properly heated up (I like a lot of glue) and then just drop it into the gearknob (which should, incidentally, be attached to the gaiter but it probably doesn't matter if it's not). Then push the knob on quickly (getting it straight) and, problem solved (y)
-Alex
