i actually have an uncle bob...
will be interested to see dyno-graphs and pics of the prototype.
1 please.Dan
:yeahthat:
Thanks for the pm, and await for the dyno results!!
Any chance you could do a back to back run wit hthe GSr kit?
Ming
recon these will be able to take boost?
The silicone will take boost, but not sure how you would mount your 2nd injector (if you have one)
PM me for more info on this.
Adam
why cant you put the info up here?
this is in the group buy section so it should be information for all?
if not then we may need to look at this thread closer
no point going via me,Ben is the man for that
did you go via the contact us link?
https://www.fiatforum.com/helpdesk/index.php
bear im mind Ben travels a lot
plus there is the automated process
https://www.fiatforum.com/payments.php
this thread was flagged up early on(as it was in Cento) but as you see i kept it and moved it to group buys
so its already been 'considered'
mine is mpi so no need for a second injector. how thick is the wall where it mounts to the throttle body. you might need to source some large jublie clips unless you can get them in that size anyway.
