General  Replace bulbs in instrument panel
susie36
Hi, This is my first post so hope its in the right place. I need to replace some bulbs in the instrument panel but I can't see how to take the instrument panel out. Please can anyone help by giving me some instructions or directing me somewhere where I can find this out. All help gratefully received. Thank you:worship:
It isn't you, these area bit buried:mad:. It's all in the archives here, could you not find it when you searched? If you cant find it then I will have a look for you
there are a couple of screws holding the black plastic surround in place. after that there are another 2 (or mayeb 4) screws holding the insutrment panel in place. then you can pull it out, disconnect both the wiring connectors, and remove it. you will need to lower the steering wheel as far as it will go.
As johnson said said one under heater vent and three on the underside of the black piece off the dashboard console along the top edge, these can be a bit of bugger sometimes.
Also when you've undone the screws remeber to unplug the headlight beam adjuster and the dashboard dimmer switch as this will make it easier to remove and/or move around.
Hope this helps
