Technical Replace back ligths
kf24b
Hi all, i have a punto sporting 1998 and need to replace some of the back lights but i'm not sure on how to remove the plastic cover. Any idea?
Also where is located the fuse panel?
Thank you,
in the interior on the C-pilar there are some round thingies, remove them and behind it you find acrew on each side. in the booth the same. after loosening the screws, you can pull out the units on the outside.
mounting, the other way around.
thank you all, what about the fuse panel? i have problem with the insight lights, cigaret lighter and the cd player. i found some fuses inside the closet but everything there was ok.
under the steeringwheel (towards the door) is a small compartment which is to be loosened with a srewdriver. Behind that there is the main fusebox.
