General  removing Ulysse Mk 1 dash surround- help!
andrew1620
United Kingdom.
I need to remove the dash panel with the rev counter and speedo in in but having probs removing the plastic surround that is in front of them. I've taken out the 5 screws that hold it in and it's loose, but there is some type of clip under it right infant of the speedo. Does anyone know how to release it?
To anyone who has this problem with a Mk 1 Ulysse, there is a screw holding the surround underneath, you have to take off the steering wheel lower shroud, shine a torch up and you will see it, needs a fairly long torx driver
