Removing rear wiper
Removing rear wiper
W
Will
Hi guys, ive noticed a few of you have done this, was just wondering what do you use to plug the hole and how do you seal the washer tube?
cheers
Alot of people have used thewindow bungs from citroen AX's (myself included. best bet is to go to a scrap yard and have a look for any type of bung for this. Some old lower trim level fiestas have a bung that should fit as they wernt fitted with a rear wiper.
Other wise measure the hole (think it'll be 25-30mm) and google '25mm blanking grommet' or whatever size it is.
Hope thats of some help.
Cal
Think im just gonna use a bicycle bar end plug, as we have loads of these at work!
what you could use is a closed grommet.these are used by sparkys to close holes in electrical cabinets.i know you can get a 25mm one. try your local electrical supplier.you can get open ones, that are used to protect cable sheathing when a hole is cut in a metal cabinet.
Yea that will do. im using a headset topcap (from a bike) on the back of mine as it has the correct thread for the AX grommet.
752
Dark Lurker
J
3
783
Dark Lurker
2
744
Sabre 23
S
P
2
527
Joske
J
