Technical remove radio help
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
task
LEEDS
hi all
can anyone tell me where to put the pins to pull the radio out. as i can't c any holes for them to fit into. orderd the facia and wireing loom. just want to make sure i do it right.
cheers heath.
To get the OE radio out of any Brava/o and Marea you need some special radio pins to get them out, never seen them outside of a Fiat dealer - any chance of popping to your local dealer and asking them to remove it for you ?
done it m8 no need for fiat tools . used 2 thin blades and popped it out . thanks for the advice though
task said:
hi all
cheers heath.
Just take a look and do that (you'll need 2 small screwdrivers)
You can buy the adaptator here (in Euros)
http://www.maxiavenue.com/detail-314.html
Regards
Sorry for my english (The French touch)
Do the same for the right side
I did it myself without "FIAT tools"
With the ISO connector A, be careful, +12V wire (RED) is NOT the +12V from ignition key, it's the permanent +12V to put on the memories wire (Orange or Yellow)
