Technical  Marea Intrument dials Removal
mareantonio
Hello,
i got a Fiat Marengo (its the comercial version of the Marea) 1.9 JTD 105cv and my speedometer stopped working.
I already checked all the fuses and relays and everysingle one is ok, so i guess the problem is either on the contacts or in the speed sensor.
I tried to remove the instruments but i can't figure out how to do it without breaking anything :confused::bang:
Can anybody give me a little help?
Cumps
Remove the black surround with airvent first.
Three screws on top of it and two behind the seering wheel (just put it to lowest position).
Remove fusebox cover on left kneecap and in there a bit right of the airvent is one screw.
Now you can pry it off (there is a metal spring clip somewhere around the airvent and taking it off is pain if it has not been done before).
After it is off you can see the screws holding the dialcluster.
