REMOTE WIRIRING/...look in..
A
ACID
bascially i bought the meta fiat remote central locking key button
and now i cant see how i managed without it
its too easy to fit, replacing current yellow relay with the meta one which is located in the glove comaprtment
however i need thsi same sort of relay
for
i) windows, as i always take my keys out but forget i left the windows open
ii) boot, as i alwasy have to pull the lever, key lock has problems frequently..
iii) can it be made remote ignition start?
Yes, but that involves a whole new unit - not Fiat standard or as an extra - you will need to find one manufacturer that can do that
Members Site - - - - - - - My Site
Cheers for ther reply
just assuemd there was astandard one
any other places i can try
only after relay
as the wirirng ones take up too much time to add on..
You could get the universal window closure kit from maplins?
Daz
are the kits easy to do, or does it require alot of wiring>>
does that mean ill need another key fob oto acivate it? besdie my central locking one?
is there any where i can just plug in a relay?
Ive got a universal window closer kit if your intersted, brand new never fitted (Too busy/lazy/cold) :) and it also closes the sunroof!!
justin
hi ill porb take it at a good price
but what i dont want is two remote keys...
seems silly haveing 2... an all in 1 is far better
also is it wiring for the kit you have or a relay???
its the whole kit i bought it off ebay for £20 so make me an offer :)
its for up to 5 doors and a sunroof. Not wired it up obviously but its meant to connect to the remote/alarm system wich trips it when the fob is pressed...
hope it helps!!
justin
J
1
1K
Frank
F
3
465
Tim R
T
S
4
409
S
