remote central locking problem
A
Anonymous
my remote has ceased to work from this afternoon. the light still flashes on the keyfob but wont unlock/lock. will still work with key though. anyone got any ideas what to try. read couple of previous posts and they say check the fuse...which fuse is it and where because i dont have a haynes or user manual. cheers folks
oh yeah its mk2 bravo 115 1999-v plate
I've got a similar rcl problem... when I bought the car I got one red key and two blue ones, one blue key had always worked fine and the other has never worked. It's the correct key as it opens the door 'manully' just not with the remote. I've tried replacing the batteries and the re-couple proceedure outlined in the manual but still no joy, the red light flashes when I press the button and everything, just no unlocking. Any ideas?? P reg Brava 1.6 ELX btw.
BTW - if it's of any help the re-couple proceedure as stated in the manual was (as best i can remember it):
1. Make sure alarm switch is set to on (by the fuse box)
2. Leave key out the ignition
3. With car unlocked and alarm off press the little button by ur interior light and alarm led with a pen and keep it pressed, led nearby should start flashing
4. Put keyfob next to little button thing and press the unlock button
5. Led should stop flashing then go constant to indicate coupling has worked.
Job done, didnt work for me but might for you, hope so.
I too have the same problem, both blue keys just stopped working. I have read on hear though of someone who resoldered the switch inside the key and that helped
K
311
Keval
K
W
922
wakka
W
R
1
553
Dark Lurker
T
1
802
Joseph
J
