- Joined
- Sep 7, 2010
- Messages
- 2,388
- Points
- 468
Do you have any connection to that company you linked to?
Apparently distilled/pure water and liquids is the only water that nature produces -
rain, fog, dew, snow, fruit juice, milk, urine.
Tremendous, getting more off topic now, but what about The Dead Sea and Mono Lake? Or acid rain. Or bio precipitation?
it also tastes better in my opinion
That's the information I can give you based on those two things, for your issue I suggest testing the CTS by unplugging it and put the ignition on - this will test to see if the ECU see's the sensor unplugged this in turn will activate the cooling fan to turn on because it thinks the car is overheating so the ECU protects the engine from overheating!
Now in a likely case, I'd say you either have a dodgy temp sender sensor or the CTS is fubar'd!
Do you get any heat from the fans after running the car for like 10-15 minutes? Like cold and hot at request?
Ben
If a removed functioning CTS causes the fan to come on, wouldnt a plugged in non-functioning CTS also cause the fan to come on?
Cheers.
Yes mate that does helpIf the ECU receives no signal from the CTS it will most likely turn the fan on, because ECU relies on that sensor to find out a rough reading of what the coolant temperature is at, without it, ECU is clueless of it, like for example if crank sensor stopped work, car would attempt to turn over but wouldn't fire because ECU needs data off that sensor to know when the pistons are at TDC and when to start the firing of the pistons etc.
Hope that helps.
Ben
so
if the CTS is dead, the fan should come on anyway with the CTS in or out?
if the CTS works, the fan should come on with the CTS removed?
But we could have a partially faulty CTS that if left plugged in wouldnt necessarily make the ECU cause the fan to come on?
so
No not necessarily. It depends HOW the CTS has failed. sometimes they fail "open circuit" if this is the case then your fan would be on al the time. Sometimes they fail partially or closed circuit. This would mean the car would think its still cold, and the fans would not come on (even if the engine is overheating) and your fueling would be well off, meaning the car would be running roughly.
No, disconnecting the CTS will only test your fan control circuit. Even if your CTS is faulty, if you disconnect it, the fan will come on.
Yes thats correct. If its partilly failed it might be constantly telling the ECU the coolant temp is say 50oC (even though it may well be 95oC and therefore no fan will come on, plus fueling will be out.
well there was no thermostat inside the thermostat housing so no wonder it was running cold.
Doesnt seem that the hole is big enough for the stat to drop inside the engine, and i cant feel any loose parts, so i presume someone removed the stat from the housing at some point![]()
http://www.ebay.co.uk/itm/Continent...arts_Vehicles_CarParts_SM&hash=item3f1e1d0b85well there was no thermostat inside the thermostat housing so no wonder it was running cold.
