littlepip17 said:and no, no matter what you here there is know way to repogram a new red key to an old ecu with no keys because the chips in the ecu are erom (electronic read only memory) you have to get them from fiat as they have a database of every key made and even the cut of the key
littlepip17 said:the easies way to tell if your car has coded kes is loking at the shank of the key it will have 2 writen on it the then som sheverons a bit like this (2>>)also there will be an arial around the ignition barel and a code light will iluminate on the dash briefely as you swich on the ignition
ive only got black key for my bravo with lil triangle on shank an 2 circles comin of triangle is mine a coded key tooarseofbox said:EPROM (Electrically Programmable Read Only Memory), EEPROM (Erasable Electrically Programmable Read Only Memory), PROM (Programmable Read Only Memory) or basic ROM (Read Only Memory).
Theres a difference and it does matter
Thats the Code2 system, the Code system is similar and underlying principles are the same....except the Code2 uses no Red Key
PEZ1 said:YES!! Thats the only key i use!
When i bought the car i only recieved this key and a blue one. Is there a differance between the two blue keys? as the one I have onlt unlocks/ locks the car and will not start it![]()
