trying to get some better pics loaded up, got pics of all the rust patchs that are worth mentioning (everything except door bottoms)
passenger side rear 3/4 panel, this is pretty solid underneath the plastic, just this one blister, but its solid, can be tarted up.
roof rear rail, again, just blistering this is on the drivers side (the bad side).
this is th worst of it, the drivers side rear 3/4 under the plastic is almost all soft an flakey, with a big gapping hole (well it will be if I breath on it) where that blister mark is (wheel arch clip area
boot, next to the passenger side light, that crack is in the outer layer of metal, the inner layer is solid/ I'm dreading whats actually underneath the bumper.
drivers side A pillar, solid, just surface blistering from a badly fitted windscreen (now sorted)
passenger side rear window hinge, its again just surface rust, and could be plated over if its bad then the black stuff will mask it.
WTF a bleed valve? is it not? anyway, I fiddled with it then went for a drive and found it was back down to 0.65/0.7 bar at max, which is better (was boosting upto 0.95 bar!!! in 5th).
reckon this is affecting its idle as well, and the fact its running rich as hell all the time.
don't know why all the photos below are blurred! was a bright day, at widest apertre and iso400
shoulda broken out the tripod
ok heres some extiorers after I cleaned it up a bit...
seats are mint.
dash and clocks is mint and all works pretty spot on
