General  Rear Wiper ???
melfortgal
First post on here! Having an issue finding a rear wiper arm for my 2011 panda. Ordered one online a few weeks ago but it’s too big and not fully clearing the back windscreen.
Any help on where to find one?
Is it possible to just replace the blade? I can't work out how it disconnects (I'm trying to avoid just replacing the rubber bit, which I know is the obvious solution, because it's always a pain)
I just keep replacing the rubber blade and not the arms with ones from pound shop swapping just the blade and chuck the rest away. You have to find blade that attached the same way as the original which should be held in with two shiny metal strips. Push them out with the blade. then replace with the new rubber blade cut to length. This assumes that it hasn't already been swap with some cheapo aftermarket already.
some blades have the rubber wiper in a plastic housing. These don't swap over easily.
Thanks, I'd been thinking about trying to just get a rubber blade insert on its own somehow. I know a rear wiper blade isn't a big deal in the greater scheme of things, but I don't like unnecessary waste.
The outer end of my rear wiper blade had worn down so that the plastic was scratching the glass when I got my Panda. So I just slid the rubber insert out of the arm, turned it round and slid it back in. Fixed!:D
