Rear Wiper Sorted
Rear Wiper Sorted
J
JonD
Finally sorted my rear wiper. Got a motor off a brava. It doesn't wipe all the way round which doesnt bother me but I think there is an adjusting screw on it anyway. Its the same model of motor.
Re: Untitled
hi jon, how much did you get the new one for?
(that my next job) :(
just.
Re: Untitled
Wrekin motor spares in Telford. There is another brava there with a motor. (If your from round here)
Re: Untitled
i live in telford anyway where about is wrekin motors (dont say the wrekin) ;)
justin
Re: Untitled
Go towards asda at Donnigton, at the roudabout by it turn left then left again a few hundred yards up the road. Then left again has yellow sign says wrekin motor spares on it.
Just need to adjust it but cant be arsed taking it off as the headrest blocks the bit that its not wiping anyway.
Re: Untitled
It seems a common problem as went to Telford Motor Spares and they had 2 bravos but neither had the motor in.
Re: Untitled
it is common, findin a spare is like findin hens teeth !!
TMS had bugger all last i went but i begrudge goin there anyway robbin b*st*ads :(
the one bravo i gots wiper just wags away like a dogs tale and the other packed up the day after buying it!! ah well if everything went smoothly it'd get boring s'pose :)
nice to know someone else on here's from telford anyhow :)
just.
Re: Untitled
If yours works but slowly it might be fixable you took it apart?
Re: Untitled
yeah tried stripped and greased the shaft (ooooerrr) it started to work and the fook-all so i guess the motors burnt out as for the wagging wiper its the missuses car now so "what he eye dont see"...... ;)
il see what comes up it aint an mot failier so im in no rush!!
just.
Re: Untitled
The end preload screw is probably too tight on the one thats stopped and the contacts probably need cleaning on the other one.
Re: Untitled
where on the shaft is the preload screw?
cheers....just.
Re: Untitled
Its not on the shaft, its the plastic screw on the side of the gearbox.
752
Dark Lurker
J
3
783
Dark Lurker
2
747
Sabre 23
S
P
2
527
Joske
J
B
644
Brian
B
