Rear wiper idle position
A
Adam
has anyone been able to get the rear wiper to idle so that it is verticly center on the rear screen.
im guessing that a realy wud be needed or replaced to get it to work correctly then idle in the centre.??
has anyone done this befor??
Cheers in advanced
Adam
Wimmy has but that's because his motor is shot! :)
Shabash!
Now partying with Yul Brynner
http://www.billhicks.com/
http://www.geocities.com/ozrictentacles_web/
No offence, but why would you want the wiper to stop in the middle...?
Daz
Just think it looks preety smart,
seen couple of cars with it done befor and looks tidy.
the only way you can acheive this is:
with car running start the wiper going, when it gets to the required position quickly shut of the ignition thus making it park where you want it.
then go into the iside of the boot and remove the panel on the bootlid. inside you will see a white connector connected to the motor itself. remove this from the assembly, tape it back so it cant touch any body panels and it will then stay where you parked it.
of course you wont be able to use your rear wiper anymore ;) but thats basically your only option without modifying the motor itself/bodge fitting a new motor from another car.
Dan
now sporting my badger badger badger t-shirt ;)
nope.
I did this when ahem I fixed my rear wiper by puting it in the wrong position.
if you accidently turn your rear wiper on because you forget you end up scratching your bootlid ;)
common sense prevails chap :)
Dan
if you remove the fuse for the rear wiper it knocks out allsorts of stuff though which is rather gay if you ask me :(
Dan
E
1K
E
743
Dark Lurker
J
3
773
Dark Lurker
2
725
Sabre 23
S
P
1
552
K
