Rear windscreen not de-misting
J
Ja
Starting to wind me up, anyone got idea of fault/cost cheers (de-mist button lights up but nobody in), also got the ticking rear wiper fault,,, ahhh wouldnt be a fiat without a few probs :)
i'm trying to connect the two faults, but i cant think why both should pack up together.
could be the heaters relay, dont know where its locted though.
Re: Re: Rear windscreen not de-misting
normally if the rear demister isn't working it is because you have caught the track somewhere and it can't make a circuit. If you have a volt meter have a prod around starting at where the demister wires come in.
Check the connections in the boot lid/boot lip.
If both things on the tailgate stopped working I would check that. Make sure they're clean and making a good connection.
Steve O
thanks for the response peeps, will have an inspection before the winter really kicks in ;)
yes check the connections on the boot lid on left hand side also ones on the boot floor you will probably find them a little melted
I have a button in my car, that when pressed - it stpos raining/snowing etc so there's no need for a demister.
Re: Re: Re: Rear windscreen not de-misting
How much was the button and can you fit 1 to my car i wanna go fishing lol
Re: Re: Re: Re: Rear windscreen not de-misting
No, Matey.
This button is only available to those who don't take themselves seriously and/or think that Fiats are relaible.
Sorry, you could try and modify a Honda/Mitsubishi/Mazda or Nissan button. They're reliable.
Yahoooooooooooooooooooooooooo!
Left hand side connector burn't out
I had the same problem with my own Brava. The connector had overheated (probably from a short)and the plastic casing had melted.
You'll probably need both the top and bottom connectors and these set me back €38 in total so it'll probably only cost you £25
M
7K
mick gibbons
M
T
3
756
Dark Lurker
892
David
P
15
12K
Dark Lurker
P
2
527
Joske
J
