firstly check your shock absorbers. push down and release on the rear of the car at each side. your car should pop back up and settle, if it tends to bounce, then your shock absorber on that side could be goosed, if it is then always replace both. secondly jack the car up and use axle stands get a torch and have a look at the springs you could have a broken spring, if so again change both. hope this helps
