Technical Rear Subframe Question
razor400
Does anyone know if a Marea saloon Rear subframe will be a straight swap for a weekend.
unfortuantely i dont have an eper to be able to confirm for you if they are the same part number but i believe they are.
the Coupe rear subframe also appears to be the same, again, i cant check the part numbers. should be aware though that the trailing arms from the coupe will cause rubbing issues if you put them on a marea like i have done.
Why do you need to replace the subframe?
Ry
Direct fit, no hassle, you might even benefit by getting disk brakes instead of drums, if you manage to find one w/disks.
