Technical  Rear Springs Replacement
Scottish Highlands
Has anyone replaced the rear springs on the multi? If so I get the impression by looking at them that they are easier to fit than the front ones. Am I right? If so what is involved in replacing them?
Very Easy
remove wheel.
undo the lower shock absorberr bolt. and the 3 that hold the anto roll bar on.
push the plastic clip out of the bottom of the spring.
get a helper to push the suspension arm down and the spring pops out.
Really easy
30 min job
S
I used a hydraulic jack to push the suspension arm just enough to fit the screw for the shock absorber. Found it easier than using spring compressor.
