General Rear Seatbelt Mounting Points?
Steven
Go on the Fiats!
Northern Ireland
After an investigation with a screwdriver to discover the full extent of my Panda's rust problem the drivers side rear seatbelt has now detached itself from the rest of the car. The other side is close to it. :(
Does anyone know if new mounting points are available from Fiat? A price/parts number would be great if anyone has an ePer disc. My ePer disc refuses to work for some reason.
OP
OP
Steven
Steven
Go on the Fiats!
Northern Ireland
No, I bought Bigjawa's 750 Formula. Basically it's a good car but it's starting to go and has been off the road for a while. I'm bringing it back to life. I hope to have it MOT'ed and ready for the road this spring.
OP
OP
Steven
Steven
Go on the Fiats!
Northern Ireland
Yes, it's the section which the seatbelt attaches to on the inside of the rear wing.
OP
OP
Steven
Steven
Go on the Fiats!
Northern Ireland
Here's a photo. You can see the inner wing, the back seat and the hole where the seat belt used to be...
Tony M
eh?
Steve said:
Thanks for looking. :) Anyone else have any ideas?
I thought that bit wasdirectly welded to the bodywork?... I noticed that the seatbelt mounting bolt go all the way through to the wheel arch anyway. should be easy enough to get a lump of metal machined to those dimensions.
petel
Established member
London
These points are supplied as part of the original " Worked body " and although a new inner panel may still be available, you would have to unstitch most of the rear of the car to replace it. As stated, a welder/fabricator should be able to effect a worthwhile local repair, though I think you will find that the area below the mounting point ( floor panel and chassis box section ) will be affected as well.
Rgds.
Newcastle upon Tyne.
your right petel, and according to the eper guide, the price is over £400 for that part :eek:
edit - what i would do is clean the surrounding area, get rid of the rusty metal, and weld in a patch. shame Steve is soo far away, as i could have done it for the price of the wire :( (if your going to do it, remember to put underseal on after the weld is cooled :))
OP
OP
Steven
Steven
Go on the Fiats!
Northern Ireland
Thanks everyone, that clears that up, thankyou. :(
Bugger it anyway... I thought the rectagular section with the thread in the middle for securing the belt might have been available. A lot of Pandas rust in that spot.
OP
OP
Steven
Steven
Go on the Fiats!
Northern Ireland
Check it out carefully Chris and get some seal in the rear arches. The only Panda I've had that hasn't been rusting there to some extent was the 1993 CLX.
