alfistiUK
- Joined
- Feb 3, 2011
- Messages
- 43
- Points
- 92
I'm getting slight cross contamination between tail lights and indicators on both rear lights.
I have eliminated the lamp units (by removing them) and the plastic plugs and the earth is perfect.
Putting a multimeter on the plug supply wires shows that the problem must be further back/ supply- electronic module???
TESTING ON OFFSIDE=
With brake on -Green/yellow wire (brake wire) ONLY 6.7v
Lights on- Yellow/black (tail light wire) 11.7V and green/yellow wire 6v
Indicator on- Blue wire (indic wire) 11.79v AND green yellow wire 5.7v- WHICH MUST BE INCORRECT.
Car battery is good- no problem starting up etc, and test results the same with engine running.
Any ideas?
Many thanks,
John
TESTING ON OFFSIDE=
Any ideas?
Many thanks,
John
