Rear drum
Rear drum
C
carterado
Ok, I have a little problem.
It seems that the hole for the bolt on the rear drum is damaged. I cant get bolt tighten in here, so my wheel is only on 3 bolts. I have tryed other bolts but have the same problem.
so how much aproximetly does that rear drum thingy cost ? :)
I can buy the drum part, for approx £18 for non ABS models and £24 for ABS models.
Joske
I guess I have ABS so that would mean 24.
Is that only for one wheel or two for both rear wheels ?
Thats each carterado. Not sure what Fiat charge though.
Joske
ok I see.
one last question. are there differences in drums between manufactures?? or are the all the same quality .....
thanks
re hub
The rear hub contains the bearing as well, if money is a problem go to scrappy, Dont know the cost of fiat but vauhall cavalier was £54 from motor factors. Just looked it up. abs is £26 +vat.from: www.shop4parts.co.uk
Thanks.
I am currently just researching.
Are there differences between manufactures ?
No differences between manufacturers. The drum doesn't hold the wheel bolts, the Hub does. The Hub costs approx £20+VAT. Like the chap above mentioned it includes the bearing aswell.
Joske
P
2
359
Joske
J
B
456
Brian
B
T
13
756
A
T
6
1K
K
J
3
541
Dark Lurker
