REAR BUMP STOPS
  • Thread starter Jason
  • Start date
  • Replies 1
  • Views 596
REAR BUMP STOPS
J
Jason
Just thought I would share with you guys how i fitted my rear bump stops. I got fed up of trying to fit them as intended, plus they usually break off after a few miles anyway! I noticed that there is a hole directly above the locating hole for the bump stop, so I cut off the rubber nipple (not as painful as it sounds) and drilled right through the stop. I then bolted it through the crossmember with an M8 x 100 bolt with a washer and nyloc nut on top. Works a treat and not much chance of it falling off :O)
Or failing that just tigerseal/gripfil them in place :)
Longest Serving BOO Member
1997 2.0ltr Fiat Coupe
- FC Performance Chipped
- Widget installed in dashboard
- EBC YellowStuff with 3G Discs
P
2
641
Joske
J
B
761
Brian
B
T
6
2K
K
J
3
899
Dark Lurker
