Really need help with sunroof.
J
Joske
Just like to add, hope everyone had a good time at the meet, pity i work weekends and couldn't come.
Ok my problem, well the sunroofs leaking and i've no idea where. Front pipes are clear. The car sits on a gradient making flow of water go towards the drivers side drainage hole.
The roof is wet in the top corner, i've had the roof lining out and i can see it drip but the actual area its leaking from cant be seen due to the sunroof frame being in the way.
I replaced the sunroof seal 6months or so ago, and i need your help. Since this bad weather has come i've only noticed this leak. I'm assuming it all started after the snow we just had. We all now about water turning into ice and causing things to expand.
It must be common for sunroofs to leak, since most cars do eventually, i just hope someone has got the same problem and knows how to fix it.
Help me out please!!!!
If i run glue all across the joints in the side gutters do you reckon this will prevent it or is glue a bad idea or will glue damage anything.
Silicon seems too bulky and i can finey squeeze glue as its not noticable since i've a special nozzle.
Many thanks to anyone who replys.
Joske
C
7K
ChrisKnottIns
C
A
5
617
M
