- Joined
- Sep 29, 2013
- Messages
- 478
- Points
- 182
I just returned from looking at my MoHo, and as per earlier posts on this fault, it may help if I tell you all that, I assumed the ASR was ok, it clearly is not. To recap- I changed a dead battery, and since then have a permanent ABS and handbrake/fluid/failure, i.e. the 2 warning lights on. But not, if IIRC, the ASR one. Turns out, altho it all was good before the battery went, I can now no longer switch on the ASR too. I had thought it was OK, but tried it yesterday. I hope to have a go with multiecuscan soon, but meanwhile, I checked all the fuses the handbook lists, for ABS, I might have missed some as the listing contains some rather cryptic naming. The year is 2005, 2.8JTD. IIRC I checked F20, F42, and another. All were Ok. I have the e-learn but coverage of the system is poor. I cannot find reference to any relays (there must be some involved?), so if anyone can advise me where to look, I would be really grateful. BTW, I see from e-learn that the 2 lights indicate EBD (distribution front/back) failure,,,,,all fluid levels and handbrake switch being correct, as they are.Cheers!
