Hi, i got an uncoded key cut for my fiat punto. Thing is, it dont open the door!! is this some sort of thing because it is uncoded? thanks for any help!
does your original work? put the 2 along side and compare the teeth.
if it doesnt work it could be down to the cutting.also you could get a cloned key from timpsons for about £30 which has the code as well
there must be some difference as if there wasnt it would work.theres nothing hugley technical. if its not turning then its not lifting all of the teeth in the lock barrel
