Technical Raising the engine
Flappjak
chesterfield, derbyshire
I've tried searching it but I just can't use the search bar maybe I'm doing it wrong, anyway I was wondering what's the easiest way to raise the engine so the gearbox and sumo doesn't stick too far down?
Spacers on both top mounting brackets.
The bottom one ( the plate to g/box) would have to have holes opened.
you might be lucky and get 10mm extra clearance.
Get 14" wheels insted or get sump and oil intake moded to more slim line look ( smaller cc ).
Look through "Scotty's Roma" thread.
Or the best and cheapes solution would be to bolt down 4x4 sump guard, no need to worry about grounding out - just few sparks. I can get you 4x4 sump guard for £20+ delivery.
As you're in Derbyshire I'm sure Dragon Man could fit it for you.
who.. what?
i got a twitch like some one said my name..
yeah sure i should be able to fit it for you.. if its going on a 2 wheel drive you would need the fixing plates from off a 4x4 welding onto the underside.. or just some stainless bolts and nuts drilling/welding to the underside of the panda... which i can do for you. (y)
