General Radius Arm Mounts - do they come off?
Stroud
Greetings!
I'm a chronic sufferer of 'While I'm in there...'-syndrome - and I'm wondering about whether the front radius arm mounts come off? Mine are a bit crispy, and I'd like to do something about it before they get crispier, or the the crispiness spreads into the nearby seams.
I know about the shims and ting that are important for the tracking and not to mix them up / lose them - but once the radius arms are off, is it as easy as it looks to remove the bracket?
It looks very straightforward, with the brackets bolted onto the radiator x-member / crumple zone areas - but are there any hidden spot welds? Will I ruin the alignment of the car if I take them off?
As the car has been lowered recently, I'm going to get the tracking done anyway, although I know they won't mess with the radius arms when they do that. Anything else I should do if I'm taking them off? I was planning on just derusting the brackets / radius rods / surrounding crispiness and painting them. The rest of the car looks extremely healthy and I want to keep it that way.
The car has done about mid 50s thousand miles and the rubbery bits look pretty healthy still.
The two front mounting holes are preety tight fit, probably to minimise reassembly error. Rear one is a slot. I've always been taking them off with rod and lower arm still attached. Been fine with tracking.
