Ducato (Gen 3) Radio
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Toe toe
Hi all
New to your forum.
I have a ducato motorhome and having problems with radio with very poor reception I have changed radio bought two different boosters arieals but to no avail it's ok when stationary but as soon as you set off you start to lose reception any one got any ideas as to a solution I was thinking off drilling the wing and fitting a good quality areal but want to be sure this would cure the problem
Anyone solved this?
Thanks in advance
Tony
Hi all
New to your forum.
Anyone solved this?
Thanks in advance
Tony
Hi Tony,and welcome, :)
what age and model of Ducato,? this is the CAB / dash radio unit..??:confused:
Charlie - Oxford
Hi Charlie
Thanks for quick reply
It's a 2009 motorhome and it's the cab radio I was told that its arial is in the near side wing mirror and they never have good reception I have fitted two booster arieals that stick on windscreen but no better
Tony
It could be noise from electronics onboard. Espescialy led DRL and motor electronics. Check everything that is installed after the original vehicle. Vi have noise from solar system regulator MPPT.
