500 Radio wires
500 Radio wires
Mikefraser93
Mansfield
Hello can anyone help please. Trying to change the radio in my wife's fiat 500 but the new radio just won't turn on. But some one previously has a ran a red wire which I think is the new permanent live then they have cut a red wire with a white stripe. Just wondered if any one knows what your meant to do
Got a meter? Or a small bulb, check what's on the wires, pretty sure the original wiring is permanent live, it's the can bus that turns on the radio, you need a switched feed ( from the lighter/power socket) for auto on, for now to check on a standard aftermarket radio connect the yellow and red together should turn on but don't leave it this way
Restore any previous alterations to factory
What year is your car? Facelift models use the Canbus to switch on the radio and thus a permanent live is required for an aftermarket radio.
For older cars you should be able to use one of those simple adapter cables. No need to cut wires.
Ok your new radio is it a branded unit say Alpine or Kenwood?
Temporarily bridge the yellow and red does it turn on?
Is the aerial connected ?
Are you sure the earth is OK?
Have you restored any previous modifications?
Are the original radio plugs still on the ends of the factory wiring?
Sorry I completely forgot about this and have had lots of things to do in the house so this took a back seat.
The radio in there atm is factory. But by looks of it some one has ran a new wire to the back of the radio. Not fed from cigarette lighter as I've just changed that to a usb one.
Looks like they have ran a piggy back wire from fuse box that is a switched live but radio won't work
