Technical Radio upgrade 2007 Maxi Van
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
agag2raav
I'm trying to upgrade the single din radio/cd player in a 2007 ducato. I'm trying to remove the clipboard and in information found on google/youtube the radio unit i have is located directly below the clipboard. In videos i've watched there is a spacer between the clipboard and radio. Even in the X250 manual it has the spacer between the radio & clipboard. I can't seem to find anything that shows the model i have. Is this because i have an australian version or have i got it wrong and i don't have an x250?
Any help or advise is apprciated.
Thank you
I did this upgrade on my 2010 van (X250), however I did not need to remove my clipboard.
I'm attaching a 'before' picture so you can compare this with your setup; removing radio and the 'letterbox' storage pocket left a double-din sized hole.
If your setup isn't like this possibly your van is a X244?
Thank you
I am unable to help with the radio installation.
An x250 will have a VIN number of the form xxx250nnnnnn......, and a six forward gears.
The earlier x244 will have a VIN format xxx244nnnnnn......., and five forward gears.
See VIN plate or registration document for the VIN.
Thanks heaps I figured out the radio install and with your help the model.
many thanks mate
