How do I find out what the radio code is?
Post all the numbers from the radio (not a photograph) then I will let you know if I can get the code for you. If I can get the code, you will need to make a small donation to the forum.How do I find out what the radio code is?
I had a Micra and the code was an unlabelled four digits printed on a warranty ticket. It was by luck that I spotted and entered it. You have probably done this already but, check all documents, owners manual etcHow do I find out what the radio code is?
Hi Davren,Post all the numbers from the radio (not a photograph) then I will let you know if I can get the code for you. If I can get the code, you will need to make a small donation to the forum.
You've posted the Blaupunkt and Fiat part numbers for the radio, I need the serial number. For your radio it will be something like BPX318XXXXXXXX and will be stamped somewhere on the radio.Hi Davren,
No trouble about the donation just let us know what is the usual amount.
On the plate from the top:
Bp - Nr
7 643 318 316
Fiat - Nr
735 388 373
A151
Class 1 Laserproduct
On side pannel:
SW - version 1.3
Traceability V. Number: D
Production week: 165
Hope that helps. Let us know if you need anything else.
John
Hi Davren,You've posted the Blaupunkt and Fiat part numbers for the radio, I need the serial number. For your radio it will be something like BPX318XXXXXXXX and will be stamped somewhere on the radio.
No... I can only calculate the code from the serial number. It will be similar to this:Hi Davren,
I looked on the side of the radio and found these numbers:
8 635 123 208.2
>St SN<
Does that help?
John
Hi Davren,No... I can only calculate the code from the serial number. It will be similar to this:
Yes.... I have the code for your serial number.Hi Davren,
I think I may have found it: BP331857227816 Does that look better?
Thanks for donating to the forum.Hi Davren,
Thanks, heaps Davren it works like a treat!Thanks for donating to the forum.
Your code is: 2221
7649372316Hey Guys!
I have a Fiat Punto II With a lost radio code.
Anyone have a code generator for this?
Thanks in advance.Regards!
Hey!7649372316
BP937213846939
Click the Donate link here: https://www.fiatforum.com/donate/
Do not use the anonymous option to donate.
7649372316
