Technical Radiio and Window Problems
justgotacatflap
I noticed the other day that the radio on my '53 JTD will only work from the set itself, i.e., the steering wheel controls have stopped functioning. In addition to that, the electric windows and sunroof(s) have also stopped.
Is this likely to be a fuse? If it is, can anyone guide me in the general direction of them. I can only see a small boxful beneath the bonnet and I can't see any indication which one is which.
Are there other fuses on this machine?
KR's & TIA
Patrick
It's the old shape. I found the fuses you mention and I've had them all out to test - none of them appear blown (multimeter test).
Have you any idea which fuse it would be in case I got confused and tested the same ones twice?
Patrick
has it got rear elec windows and do they work.is it the front windows that dont work,if so check the following.
Looking at the fuse box in front of the drivers side glove box, with the connectors upper most,there are 5 rows of 3 fuses.Attached to this are more fuses.there should be only one 30A fuse in a GREEN base.check this fuse it controls both front windows and sun roor.if fuse ok check there is 12v at one terminal were the fuse has come out of.you will have to remove the silly guard over the fuse..................
Yes MP
I found the green fuse you mentioned and its OK
Yes, it does have elec rear windows and they don't work either! I think it's going down to the Fiat dealer this week!
Thanks anyway
Patrick
