valeriovanni
I have a Stilo 1.8 Multiwagon, mid 2003.
The issue is that the radiator fan doesn't start. I try to report here all the data found so far.
I connect Multiecuscan -> actuators
FAN 1 speed: nothing happens
FAN 2 speed: error "unable to execute test"
The second outcome doesn't surprise me, since this circuit seems to have only one speed (see below).
So I tried to look at fuse boxes. I don't have original manual on paper, I downloaded one from Internet named 00_192_STILO_603_81_010_IT_02_11_06_L_LG.pdf.
But it says, about 1.8 (fuse box near battery):
F06 30A FAN 1 speed
F07 50A FAN 2 speed
And it's plain wrong: In F06 there's a 50A, in F07 no fuse. Note: I'm not talking about a missing fuse, there is no connector below. Fuse blades fall into void.
So, can I trust such a pdf?
Then I digged again, and according to https://4cardata.info it seems that the correct scheme for 1.8 and 2.4 is this:
It reports a power positive conductor through F06 (50A), and a control positive line through F16 (7.5A).
They both go to a specific ECU for fans, behind radiator, M150.
To M150 go, in addition, a power earth (thick cable) and a control earth from engine ECU.
Then a couple of cables go out from 150 to fan motor.
Rather simple: 2 power cables IN (+ -), 2 control cables, and 2 power cables OUT (+ -).
Mi project was to remove M150, detach connectors and then test
-if power cables carry current
-if control cables carry current
-if I put current on out, does fan start?
But project failed: I removed M150, but there is no connector. Cables go into rubber.
I tried to dig rubber with fingernails, but then I stopped because I felt I was doing mess.
And then I decided put some liquid rubber to repair.
"M150" component is not a simple box as in the picture, it includes cabling. This explains why colors of cables of M150 don't mach with the ones on picture: picture is related to the companions at end of these cable, not at the cables themselves.
So the next step would have been to find end of cabling. But, before, I tried some test with fuses.
I tried to remove F16 (command +), and it was ok. But when I took it out I heard a multiple bell from inside. "ASR failure" "ESP failure".
Does it make sense? I think not... I take out the fuse that sends a positive to FAN ECU, what does ASR and ESP have to do with it?
Then I said "let's try to check the other 7.5A fuses down there. Just hoping that some data was coherent... that the broken fuse a 7.5 one.
So I tried to take off F19... it was ok.
Then I tried F18... still ok, but this time when I took it off the fan started. But not with actuator test, it simply started when I took off the fuse.
And this? What does it mean?
At that time I learned that
-FAN motor is ok
-M150 ECU is ok. It has a line in, a line out, and a trigger one. If fan starts, a trigger is received.
But why taking off a FUSE (of another circuit) should trigger M150?
In pdf manual, F18 is labelled as "+30 electronic injection system". But, as I said, how can I trust that pdf?
F06 30A FAN 1 speed
F07 50A FAN 2 speed
-FAN motor is ok
- Model
- Stilo 1.8 Multiwagon
- Year
- 2003
