- Joined
- Apr 29, 2013
- Messages
- 72
- Points
- 29
Pretty much as the title suggests. Absolutely no idea how to do it, my previous attempt caused water ingress, so would love some fresh ideas on how to do it.
Thanks.
Thanks.
Hey, I did this 2 weeks ago, I was confused myself, turns out it's surprisingly simple, follow the thick bundle of cables from the inside of your bonnet on the right hand side, they should lead underneath the plastic cover at which the wipers sit on top of. Now all you need to do in un-screw this, lift it up slightly and you will find yourself a rubber gromet at which you can drill through and thread the cable down into your car.
We couldn't find a way from the battery to the cabin through the bulkhead so we put it by the doorframe and then through the door sill plastics
No, 100% water tight. Drill a smaller hole through the rubber gromet than what your power cable is and when you thread the cable through it will be tight so no water can pass through.
It's worked well so far lol , as I live in scotland it rains a lot and Iv seen no leaks yet lolDO NOT DO THIS!
I did this and it caused water to slowly creep in, luckily no electrical damage/corrosion. Just some drenched sound deadening that I was able to dry out in the airing cupboard.
