M matto1992 New member Joined Jun 22, 2009 Messages 55 Points 31 Location spalding Jan 6, 2010 #1 I put a universal air filter on my car and put it where my air box use to be and about 2 weeks later my MAP sensor went. Is it because of the air filter?? And is it normal for them to use more fuel??? Thanks matt
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 5,006 Location Liverpool Jan 6, 2010 #2 Probably not. MAPs don't seem to worry overmuch about aftermarket filters -- I hear that Alfa MAFs dislike them with a vengeance. The fuelling thing could just be the weather.
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 4,003 Location Lake District....Moist Jan 6, 2010 #3 If you put the new filter on top of the gearbox, then it will have had no effect on the map sensor. Was it the sensor or the pipe full of fluid that caused the failure? Cheers SPD
OP OP M matto1992 New member Joined Jun 22, 2009 Messages 55 Points 31 Location spalding Jan 6, 2010 #4 rallycinq said: If you put the new filter on top of the gearbox, then it will have had no effect on the map sensor. Was it the sensor or the pipe full of fluid that caused the failure? Cheers SPD Click to expand... It was the sensor because was plugged in a modis and it came up with that fail code. cheers matt
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 4,003 Location Lake District....Moist Jan 6, 2010 #5 matto1992 said: It was the sensor because was plugged in a modis and it came up with that fail code. cheers matt Click to expand... Careful, the fact that its not behaving doesn't mean the component itself was the cause. Remove the MAP pipe and blow it out over clean paper to make sure its not contaminated. Visually check the pipe and the connections for splits. Cheers SPD
