Technical Punto where is oil leaking?
kbcitdsh
uk
hey my friends,
can anyone tell me where all this oil is coming from? it's a fiat punto 1.2 60hp
@George1982 @varesecrazy you were right. i took out the ignition coil bracket and saw that the oil was leaking from there. now I'll buy some silicone sealant to fix it. thank you very much
Put some sealant around the o-ring, and some sealant around the coil packs Mounting Flange.. it will squash against the engine block when you tighten those bolts :)
