Technical Punto Problem
dangreening11
Felixstowe
Good Morning
i currently own a Fiat Punto 1.2 8v 54 Plate
the brake pedal and gas pedal have just start to become alot harder and they keep going from hard to soft
there a bit tempermental, and im just wondering what is causing this
thanks
regards
dan
the front brake pads have just been changed like a month ago
i dont know much about installing new pads so i got someone else to do it
when the engine is off, you can press down the brake pedal, but it goes hard once you repeatedly pump it, as most do
the car is getting a major service next month as the mot runs out
its starting to get worse today and it tends to be more hard now, and it isnt exactly ideal when you try and brake and you dont get alot of response straight away, due to the hardness of it, you need to give it a fair old push down
im going to leave it until next week as they will be rebleeding the brakes & renewing brake fluid
if i still get the problem once its all serviced, then i shall go back to the drawing board
