alltvrepairs
- Joined
- Apr 6, 2015
- Messages
- 7
- Points
- 2
I have repaired quite a few Punto Mk2 steering motors replacing relays, joints etc.
However I have now the usual Punto MK3 steering column fault which needs sensor replacement. The sensor column is already on the bench.
I have a scrapped unit that may do some testing on. Tried searching this forum to find a disassembly's instructions to the sensor level. Not sure if this detail is found in Haynes manual. But all the videos I have seen show the unit already dismantled.
I have a large nylon gear on top of the torque angle sensor and not sure what is the best way to split apart without damaging the unit.
After this I would be able to continue myself as have the equipment to calibrate the unit etc.
Your help much appreciated. I may update this page wit more information if I get the required help.
Thanks for reading!
Thanks for reading!
