Hi all, new member here, just picked up my '03 plate Fiat Punto Active 1.2 yesterday and am well chuffed with it. Was giving the car a good clean and a once over today and noticed when testing out all the bulbs/electrics that the drivers side door speaker wasn't working! grrrrrr. I have listened around and all the other speakers are working - it looks like I have 2 in the doors, 2 at the back, and a couple of little tweeters towards the dash. Now from what I can tell it sounds like the door speakers handle the bass end with them being the biggest drivers, mid range from the back speakers and obviously high end from the tweeters.
I have turned my stereo up and it seems like this is the case as the bass is lacking. And I'm a bit of an audiophile and I like my tunes so this simply will not do! It will greatly get on my nerves if I don't fix it.
First things first, I took the speaker off to check it was connected at the back (I figure as it's only 1 speaker not working then the problem was the speaker end rather than the head unit end, especially as the head unit was working perfectly in my last car - although I did give the plugs/wires a wiggle just in case) So when I took the speaker off it wasn't connected - nice one, I'll just plug it back in and it'll work, problem solved. Plugged it back in and still nothing.
I swapped the speaker over to the passenger side and plugged it in there and it worked, so I know the speaker is not the problem. It must be the wiring. Wires and connections look ok with nothing broken/snapped or anything, so I figure one of the cables must be bad between the head unit and the door somewhere.
Now I don't want to go to all the hassle of taking off all the bits of bodywork and undoing the loom to trace it all back. How easy is it to just run a new pair of wired from the head unit down through to the speaker? I want to fix this and see how the standard sound system sounds before I go buying any aftermarket speakers/amps, as I don't want to spend loads of money if I can live with the system already in place.
Cheers - apologies for the long post!!
sKiTz
