Did some searching but didn't come up with anything that matched my cases. I currently have 2 weird problems with my punto mk1 75sx.
The first one is with the lights. When i put my normal beams on, the high beams seem to also turn on but only partly. I can tell this because the high beams light signal inside on the cluster turns on but its only faintly lighted, then when i actually do put on my high beams it brightens fully. I unscrewed the ground that comes from the headlights wiring and cleaned it with WD-40 incase it was a case of a bad ground but there was no difference what so ever.
The second one is really weird. The cars seems to make some sort of strange whinning sound but only when turned off. Most commonly i hear this noise when i come back from a trip. I park the car, turn the engine off and once i close the door i hear the strange sort of whinning sound... sort of like a dieing horn (if that makes any sense
). Ive also heard the noise other times randomly aswell but in all cases the engine was turned of so it cant be any worn belts or grinding parts etc.
Anyone have any clues to what might be causing these strange problems?
