Punto MK1 speaker problem!
Willber
Leeds
Hey Guy,s
Just joined here after reading about Fiat modding!
I have got a Mk1 Punto and am just using the standard stereo that came with it, i.e. 4 speaker one found in SX.
However the 2 front speakers rattle, they dont distort as such, they just rattle when there is a bass load on them. They still rattle even when the sound is faded right to the back, and they still do it when the bass is turned to the lowest setting.
Could this be a loose connection or are the speakers just knackered?
I am unsure as to what to do at the moment as I am looking to buy a CD HU and maybe some 6x9's in the back. I dont need anything huge so I was thinking of just using the existing front speakers as a mid/tweeter. It's better than not using them at all and having the soundstage all the way in the back.
Would it be worth buying some replacement original speakers and see if they work, or is there a way to fit some after market speakers into the original mountings?
Look forward to hearing your views,
Cheers!
P.S. sorry for the long winded post ;)
Willber said:
Hey Guy,s
Cheers!
You will notice a difference if you upgrade the speakers - you can get direct fit replacements :)
Thanks for the help.
Can you point me in the direction of some replacement speakers that will fit in the original dash mountings?
http://caraudiosecurity.com/shop/product_list/c_path/60_66_102/spd/8cm---3-5-speakers.html
they will all fit (the ones with 2 screw holes only)
but getting the magnets in can be trouble, i have the jbl ones and the grill sits about 1cm above where it should, but you can normally sort this by cutting the grill a bit of the dash under the speaker.
also it is recommended that you get a bass limiter thing attached to the front speaker outputs, because none of them can handle bass at loud volumes!
