Hi Gurus,
I have the following problem on my punto TD 1999 (T reg).
It ran just fine and started every time whether the dash code light (key above it) was on or off. All of a sudden it has started to play up. Intermittently the code light on the dash will not go off after inserting the ignition key and the car fails to start. Generally after a couple of goes, the light goes off and the car sparks into life. It seems to be getting worse and now has taken me over an hour to start it. Can anyone advise me on why this is happening? The problem is very intermittent and follows no particuular logical pattern. I have checked the hayes manual and there is no mention of an ecu for the punto turbo diesel . I have checked the righ offside inner wing and no sign of an ecu.
Can anybody help me with the following unanswered questions:
Is there a way to completelly disable the code check / immobiliser so that it starts every time?
If so who can do this (can i do it)? Contact info appreciated.
Is there an emergency startup procedure? what is it?
Where is the ecu located? where is the immobiliser located?
How do i test the pick up ariel located in the ignition switch?
Many thanks
dlicheri
Many thanks
dlicheri
