Technical  punto indicators flashing too quick
steveo711
Hi, help needed, my punto has failed its mot on the indicators flashing too quickly. Checked all bulbs and earth leads. Cheers
This could be really simple but check you bulbs are the correct wattage.
When fitting LED or after market bulbs the resistance can be reduced enough for the flasher relay to flash too fast.
Either that or there's an issue with the relay itself. £4 from a part slinger and a two minute job.
Any garage worth urinating on will have picked it up and offered to fix it for a few quid. Good luck. :)
i had this problem just the other week, but only on the right side. found that the right rear indicator wasn't flashing aswell, so took out the cluster and checked bulbs and tried again, worked fine :confused:. have had problems in the past with my left rear light cluster wiring and it turned out that the indicator would tick/flash really fast if the rear indicator wasn't getting signal. tucked everything back in carefully and working ok now.
i assume all your indicators were flashing? doubt you're having the same problem but hope it helps
