Technical punto front stub axle
i am planning to replace front stub axle on a punto mk1 1994, on the picture below i have marked what i think is the stub axle but dont know for sure, also how long it should take to replace it
does stub axle from a mk2 punto 2000, fit mk1?
picture is not from a punto but should be the same
yea i was meaning to say that i need to change track rod end as my wheel shakes when reaching around 90 kmh
track rod end from mk2 fit mk1?
it may appear it fits as this guy on ebay got written 1994 - 2006
As Blu73 says, make sure you get your tracking checked. Even if you measured everything before replacing the track rod, it is most likely that you will have altered your steering geometry, which will cause unequal wear of your tyres.
Getting back to the vibration, I presume you have checked the most obvious cause and had the wheels balanced!
Did you check tyre balancing? Also brake disk might be warped or overly worn
