Lassie1970
- Joined
- Feb 28, 2014
- Messages
- 8
- Points
- 3
Hi All. I have an ancient, much loved Punto which recently refused to start one morning and continued to misfire. Having found a mobile mechanic the diagnostics pinpointed the cam belt as the issue. This was found to be 4 degrees out whatever that means (female - sorry!) The cam belt had been slipping and the necessary parts were removed/replaced yesterday. The car is driving again but was a little juddery this morning when idle or at junctions as though it has lost some power. The mechanic cannot be sure whether a valve has been damaged or not with the cam belt having slipped. When driving normally/at speed it drives perfectly. However, reversing into a space this morning it was making an awful grating noise - can this be connected or do you think this is a separate issue? I will speak to the mechanic but as I'm at work and can't make calls I thought I'd ask here first! Thanks.
